Sorry, but that doesn't help very much. How the device is connected is neither here nor there, and I don't really have access to IBM PDKs (except some very old ones) without getting special agreements from IBM. Even then I'd need to know the precise process variant, and the device name.
This isn't a suggestion that you post the process name and device name here, since even then I won't realistically be able to get the answer for you. Try looking in the netlist to see what the name of the component is for I15, and then look in the model files to look for that component name and see what components are in that subckt. That might help more. If you then get stuck, perhaps you should ask IBM?
