Jul 18th, 2024, 5:22am
question about continuation methods (Read 3956 times)
RobertZ
the art of analog
San Diego, CA
Jun 20th, 2005, 5:14pm
Hi, all,
In a DC operation point simulation, the simulator tried "homotopy = gmin" first and failed; then it tried "homotopy = source" and failed again; at last, it tried "homotopy = dptran" and successed.
So, in the above situation, do I need to change some settings of the simulator, or do I need to re-design my  circuit?
I have read the 2nd chapter of Ken's book, but not found the answer of my questions.
Any commends are welcome!!
Thanks advance.
-driveforce
Robert
Re: question about continuation methods
Reply #1 - Jun 20th, 2005, 6:35pm
You have two choices.
1. You can do nothing. This is by far the most popular choice.
2. You can set homotopy=dptran on the DC analysis. This would cause subsequent dc analyes to run a bit faster.
Do not re-design your circuit. The fact that a particular homotopy method does or does not work on you circuit is no reflection on the quality of the circuit.
RobertZ
the art of analog
San Diego, CA
Reply #2 - Jun 20th, 2005, 7:00pm
Thank you, Ken,
-driveforce
Robert
