lianming1
Hi, I am simulating differential cascode OTA with Hspice. I meet one problem when I do .pz simulation. and hspice give me following message in the list file:
* project opa_cascode_test_3 ****** pole/zero analysis tnom= 25.000 temp= 25.000 ******
input = 0:vin+ output = v(out+
**warning** pole analysis stopped - iterno .gt. 100 xreal= 4.52848E-14 ximag= -1.11504E-12 ***** no poles found ***** coeffd = -3.013e-01 **warning** zero analysis stopped - iterno .gt. 100 xreal= 4.12406E-14 ximag= -1.30545E-12 ***** no zeros found ***** coeffn = -8.185e+03
***** constant factor = -8.185e+03 ***** csdfcntl: error in cio Write funtion csdfcntl: error in cio Write funtion
Can you help me? thanks a lot!
Best regards!
lianming1
