Jul 18th, 2024, 5:33am
pz simulation of differential OTA (Read 2431 times)
lianming1
Jun 20th, 2005, 6:59am
Hi, I am simulating differential cascode OTA with Hspice.  I meet one problem when I do .pz simulation. and
hspice give me following message in the list file:
* project opa_cascode_test_3
 ******   pole/zero analysis              tnom=  25.000 temp=  25.000
     input =  0:vin+                 output = v(out+
**warning** pole analysis stopped - iterno .gt.    100
         xreal=    4.52848E-14 ximag=   -1.11504E-12
***** no poles found *****     coeffd = -3.013e-01
**warning** zero analysis stopped - iterno .gt.    100
         xreal=    4.12406E-14 ximag=   -1.30545E-12
***** no zeros found *****     coeffn = -8.185e+03
***** constant factor = -8.185e+03      *****
csdfcntl: error in cio Write funtion
Can you help me? thanks a lot!
Best regards!
lianming1
