Not really an Analog Design problem but rather an Entry Tool problem (different forum).
If you're using IC5141, then you can select a wire, do edit properties, and change the colour from the edit properties form.
If in earlier versions, then presumably all the colours have changed (i.e. all wire segments rather than just one). If this is the case, you probably have a display.drf file which is redefining the "wire" packet to be some different definition.
