Apr 28th, 2024, 5:35am
How to force rise/fall time? (Read 3144 times)
Tommy
Tokyo, Japan
Jun 27th, 2005, 2:48am
  How to prevent spectre from resetting rise and fall time of transition filter?
Warning from spectre at time = 3.35988 us during transient analysis `tran'.
   I11: Value specified for rise or fall time (30 ps) for transition filter is
       too small.  Value set to 80 ps.
       This message will not be repeated for this filter.
How to prevent spectre resetting to 80ps?
Tommy
Re: How to force rise/fall time?
Reply #1 - Jun 27th, 2005, 7:59am
Spectre only has a finite resolution for time. What this message tells you is that Spectre is unable to resolve such a small difference in time (30ps) relative to the total length of the simulation time interval. The only way to avoid it is to
1. specify a longer transition, such as the 80ps it suggests
2. reduce the simulation inteval (the stop time specified to the transient analysis).
Reply #2 - Jun 27th, 2005, 11:22pm
In addition, in MMSIM60 USR1 and later, there is now an option for transient "transres" which allows you to control this. From spectre -h tran:
Quote:
26      transres=1e-9*(stop-start) s
                         Transision resolution. The transient analysis
                         attempts to stop at beginning and end of large
                         transitions (ex. corners of rizing/falling edge of a
                         pulse). If such events occur within a time less than
                         transres, the analysis will combine the events into
                         one and stop only once. This may lead to loss of
                         detail.
