Aug 26th, 2024, 2:28am
Distortion analysis for highly linear circuits (Read 120 times)
Vivek Sharma
Guest
Jun 28th, 2005, 7:15am
I am trying to simulate the linearity of an opamp in a 20-bit delta-sigma application. I would like to simulate it in Spectre.
I am not sure how I can manage this. In order to see the harmonics, I need to achieve a noise floor of about -120 dBFS and this would require simulating the circuit for about 2^20 samples, which is out of question. Moreover, I read in the docs on this site that PSS-based analyses dont work for delta-sigma ADCs as they do not have periodic states, or atleast the period is usually too large.
Is it possible to simulate the nonlinear distortion in some way?
Vivek
  IP Logged
Re: Distortion analysis for highly linear circuits
Reply #1 - Jun 28th, 2005, 8:34am
Vivek,
  Should be no problem simulating the op-amp and
getting the noise floor you are targeting. However,
simulating the op amp by itself really is not meaningful
and you will probably need to simulate the entire
Delta-Sigma ADC to make the measurements you
need. It should be possible to look at the distortion
without running 2^20 points. Somewhere between
2048 and 16384 should be enough, look at the FFT
plots in the following document, they use 65536 point
FFT and have plenty of dynamic range.
http://www.imse.cnm.es/esd-msd/WORKSHOPS/MIXMODEST/PRESENTATIONS/medeiro2.pdf
Some other things to watch are:
1) You need to use windowing function when performing
    the  FFT, for example, the hanning window. Unlike
    Pipeline ADC, windowing is required when performing
    an FFT on a Delta-Sigma ADC
2) You also  need to control the simulation accuracy, try
    using Spectre's relref=pointlocal and
    method=gear2only
BTW, if you do this simulation at transistor level it will
take a while, filter the outputs to prevent filling up the
disk. Also consider strobing the outputs, again to minimize
the data size.
Vivek Sharma
Guest
Reply #2 - Jun 29th, 2005, 6:50am
Hi Sheldon,
Thanks a lot. I am able to observe the harmonics very clearly now. I previously used coherent sampling and a rectangular window. Usually, this approach works quite well for me, but in this case, the window transfer function was getting in the way.
I am sure that I will be able to test the THD in the overall system with this scheme.
Vivek
  IP Logged
