May 2nd, 2024, 8:31am
i want help (Read 4075 times)
ZoRRo
i want help
Jul 03rd, 2005, 2:01pm
i want know how i can generate sawtooth by using vhdl code with 20MHz as frequency
hjee
Suwon, South Korea
Re: i want help
Reply #1 - Sep 28th, 2005, 7:52pm
I think you can generation a line waveform to time and try with the mod() function in the math_real package
Paul
Switzerland
Re: i want help
Reply #2 - Sep 29th, 2005, 7:57pm
Are you considering VHDL or VHDL-AMS?
Paul
Amrsfmt
change over
Egypt
Re: i want help
Reply #3 - Mar 20th, 2006, 12:35pm
hi,
I think there is a tricky solution for this,
see this
signal   pulse_signal : voltage := voltage_max;
begin
  if domain = quiescent_domain or domain = time_domain use
    v == pulse_signal'ramp(period-flybacktime, flybacktime);
  else
    v   == ac_spec;				-- used for Frequency (AC) analysis
  end use;
process
begin
   loop
    pulse_signal <= pulse;
    wait for (period-flybacktime);
    pulse_signal <= initial;
    wait for (flybacktime);
  end loop;
end process;
end architecture ideal;
Now take into consideration to declare the variables I used well
please if is there is something please post,
Amrsfmt
Solve this out
