Jul 16th, 2024, 5:41am
Current sense (Read 6583 times)
noreng
Current sense
Jul 19th, 2005, 2:56am
How do I make a current sense in Verilog-A?
Eugene
Re: Current sense
Reply #1 - Jul 19th, 2005, 9:00am
If you simply want to sense a current so you can use it in the same module, simply use I(p,n). You may need to add a node for the current sensor. For example, suppose you want to sense the current flowing into an input pin, "in". Try:
electrical inx; //defines an internal node
LHS variable = ...I(in,inx)...;//uses sensed current
You would then use inx inside your module in place of in. Beware that the current sensor shorts the nodes "in" and "inx" together. The current sensor is like a voltage source that has zero volts across it.
Re: Current sense
Reply #2 - Jul 19th, 2005, 9:12am
Eugene -
I think the recommended way to sense a port (terminal) current is with
LHS = ... I(<in>) ... ;
-Geoffrey
Eugene
Re: Current sense
Reply #3 - Jul 19th, 2005, 10:27pm
Thanks Geoffrey.  Am I correct in assuming the single node current sensor only works for ports?
noreng
Re: Current sense
Reply #4 - Jul 20th, 2005, 12:19am
Thanks for your reply.
Yes, I want to sense a port current and I've noticed that I(in) short circuits in to ground.
However, I've tried your advice, but it didn't work. I get the following error messages:
In file src/switch_sense.vla line     52:
        LHS sense=I(p);
[Failure] Syntax error : received IDENTIFIER
         while expecting '('
                      or '[' or '='
and
        LHS=I(p);
[Error] Symbol LHS has not been defined
Error: (valog) Compilation: Analysis failed.
Re: Current sense
Reply #5 - Jul 20th, 2005, 3:53am
It wasn't something to use literally. LHS meant "Left Hand Side" and was a placeholder for some left-hand-side expression (e.g. some variable, or a contribution statement, or something like that).
Try reading Ken and Olaf's book on Verilog-AMS.
Re: Current sense
Reply #6 - Jul 20th, 2005, 4:21am
Eugene - Yes, that is special syntax only for ports (aka terminals).
One typical use of a current sensor is a controlled source:
module ccvs(in, out);
  inout in, out;
  electrical in, out;
  parameter real gain = 1;
  analog begin
    V(out) <+ gain * I(in); // shorts "in" to ground
As noted before, this shorts "in" to ground, and then measures the current flowing through this shorted branch to generate the output voltage.
One might use the I(<port>) syntax in a more complicated module
module bjt(c,b,e);
  inout c,b,e;
  electrical c,b,e;
  real ic, ib, ie;
  analog begin
    // put BJT equations here
    ic = I(<c>);
    ib = I(<b>);
    ie = I(<e>);
    $strobe("Terminal currents: i(c)=", ic, " i(b)=", ib, " i(e)=", ie);
