Jul 16th, 2024, 5:36am
discipline error in Verilog-AMS (Read 700 times)
coldfire1029
Jul 21st, 2005, 8:35pm
I am trying to simulate the D-flop that is in this website.
http://www.designers-guide.org/VerilogAMS/functional-blocks/dff/dff.va
I am getting error msg: . Help appreciated...thx.
ncelab: *E,CUVDNF (/test/dflop_tb/schematic/verilog.vams,17|15): Could not determine discipline for this expression .
qb ), .q( q ), .d( d ) );
Here is my testbench:
`include "disciplines.vams"
module dflop_tb ( qb,q,d );
output   qb;
output   q;
input   d;
dff1 (*
integer library_binding = "test";
I2 ( .clk( net13 ), .qb(
vsource #(.delay(5u), .type("pulse"), .period(500p), .width(250p), .edgetype("linear"),
.val0(0.0), .dc(0), .rise(50p), .val1(1), .fall(50p)) (*
integer
library_binding = "analogLib";
Re: discipline error in Verilog-AMS
Reply #1 - Jul 22nd, 2005, 12:41pm
The dff1 that's on the web site sets its ports to be "voltage"
output q; voltage q;      // Q output
I'm used to seeing ports declared as "electrical."  In this case, it shouldn't matter, since the through variable (current) isn't used.  However, it may be that the simulator you have doesn't actually define "voltage" as a discipline, but rather only defines the nature "Voltage."  Try changing them to "electrical", or add this after the `include:
discipline voltage
       potential    Voltage;
enddiscipline
-Geoffrey
