Jul 16th, 2024, 5:35am
Separating real from imaginary (Read 5336 times)
jefkat
Aug 05th, 2005, 6:49am
Hello everyone,
     I'm trying to make a complex impedance meter. Well to begin with I can connect an external voltage source to an external impedance, sense the current inside the module and then find the impedance ...
      How about real en imag. parts? any idea?
     Thanks for your comments
    bye
      shafkat
Eugene
Re: Separating real from imaginary
Reply #1 - Aug 5th, 2005, 10:45am
Since your post is in the VerilogAMS section I assume you are asking a modeling question, not a circuit design question.
How would you connect the meter to the device under test? Are you trying to find the impedance looking into a pair of nodes? A transimpedance?  Are you trying to measure a small signal impedance or a large signal impedance?
jefkat
Reply #2 - Aug 8th, 2005, 12:08am
well yes, it's the same as measuring the impedance bw two nodes.  I connect the meter to two nodes. Internally short them by making their volt. difference equal to 0 (in the module). The voltage at the terminal is known so I need to sense the current to find the impedance  Z= V/I.
Now an AC analysis quits at this statement saying it is a divide by zero. This is driving me nuts ,,any help !!!
Thanks anyway.
shafkat
Reply #3 - Aug 8th, 2005, 1:22am
You cannot measure impedance in Verilog-A/MS because it is a time-domain language and impedance is a frequency-domain concept.
You are no doubt getting the divide by zero because the DC current I is zero. Remember that AC analysis linearizes about the DC operating point.
Eugene
Reply #4 - Aug 8th, 2005, 8:11am
If you are trying to measure an AC impedance (which involves small signals), why wouldn't you simply drive the pair of nodes with an AC current source (0 amps DC, ACmagnitude=1A) and observe the AC voltage? Why do it through AMS?
jefkat
Reply #5 - Aug 8th, 2005, 8:33am
Thanks for your time guys..
Well I wanted to characterize different technology caps..
I am not using simply AC analysis to avoid using calculator.
Besides I need some other parameters as well like
Q.  And it is important for me to be able to separate real and imaginary parts   (parasitics determination).
Alright thanks again..
have a nice day
shaf.
