Jul 16th, 2024, 5:49am
diode modeling (Read 897 times)
Zorro
diode modeling
Aug 09th, 2005, 4:17am
hello everybody,
I am writing a model that contains an internal diode. this diode is only used when a certain condition arises, and is therefore embedded within an if statement. The equation I am using is:
  I(Diode) <+ is*(exp(V(Diode)/$vt)-1)
However I tend to get convergence problems, and when I try to use the limexp function, it compiles ok but the elaborator does not like it. It says that is only possible to use it outside of the if statement.
I do not want to perform the limexp function outside of the if statement and return the result inside the "if" when called, because then the simulator is having to make an unwanted calculation constantly, and hence slowing the process down and using more memory space.
So my question is, is there a way of using the limexp function only when called (i.e. the if statement becomes true)?
Douglas Paniagua  :P
Zorro
Re: diode modeling
Reply #1 - Aug 9th, 2005, 4:34am
hello just one more thing,
Is there a way of usíng any of the analog operators such as "ddt" iinside conditional statements?
Cheers,
Douglas
Re: diode modeling
Reply #2 - Aug 9th, 2005, 4:46pm
Try limexp() rather than exp().
You cannot have the ddt operator inside a conditional unless the argument to the conditional cannot change during an analysis.
Re: diode modeling
Reply #3 - Aug 18th, 2005, 10:25am
Ken -
You missed his comment that he wanted limexp() inside a conditional.
Zorro -
If the test condition depends only on parameters, then you would be OK -- for example, I have a diode model that checks if BV for the diode is specified, and uses limexp conditionally.
-Geoffrey
