Aug 17th, 2024, 3:18pm
IIP3 @ 10MHz offset for WCDMA (Read 4053 times)
boshiouke
trying to learn
Aug 11th, 2005, 11:33am
The inband IIP3 for WCDMA is specified @ 10MHz offset. So I ran a 2-tone test w/ following parameters,
RF1=2150MHz
RF2=2160MHz
LO=2140MHz
First of all, should I have used the 2 tones @ 10/20.5MHz so that IM3(0.5MHz) falls within the BW(5MHz)?
Secondly, due the LPF @ mixer output w/ cutoff of 8MHz, the output @ 10MHz is much bigger than @ 20MHz. In this case, how do I calculate IIP3? Does "Pin+1/2 x (delta between fundamental and IM3)" still apply? Which 2 frequencies should I take the delta from? Assuming the Pin is in linear region of the mixer.
Thank you so much.
Re: IIP3 @ 10MHz offset for WCDMA
Reply #1 - Aug 13th, 2005, 8:22am
Hi.
IIP3 is component's specification not WCDMA specification.
Instead of IIP3, IM sensitivity requirement is specified in WCDMA,
Interferences are defined like followings.
 U1 ; Non-Modulated Interference +10MHz apart from Desired Signal
 U2 ; Modulated Interference +20MHz apart from Desired Signal
For component level design, you have to translate IM sensitivity to IIP3.
If you have Filter limiting IF bandwidth, you must compensate this effect
for tranlating IM sensitivity to IIP3.
>RF1=2150MHz
>RF2=2160MHz
>LO=2140MHz
I can't understand your question.
What does it mean by "2 tones @ 10/20.5MHz" ?
You mean RF1=LO+10MHz, RF2=LO+20.5MHz, IM3=0.5MHz and 31MHz ?
I can't understand your sentence.  ???
With LPF of fc=8MHz, RF1=LO+10MHz, RF2=LO+20.5MHz,
resulting frequencies at IF port are IF1=10MHz, IF2=20.5MHz, IM3=0.5MHz.
You mean IF1 and IF2 are out of pass band ?  ???
(1) Determine substitute RF1, RF2 and IIP3 where all IF1, IF2 and IM3 are with in in-band.
(2) Apply loss due to LPF for IF1 and IF2.
There are other methods.
Which methods you use is your own task.  :-/ Undecided Undecided
Frank Ke
Guest
Reply #2 - Aug 13th, 2005, 3:09pm
Thanks for the reply. I'm sorry that I wasn't clear on my description. I was trying to simulate the IP3 for the Rx Mixer, with a 2-tone test. Since the inband IP3 for WCDMA is specified @ 10MHz offset, the 2 tones will fall out of the signal bandwidth given the fact that WCDMA's BW is only 5MHz. Therefore, I am not sure about my selection of the 2 tones. Should I use LO+10MHz and LO+20.5MHz so that one of the IM3(0.5MHz) will fall within the BW? There are papers that claimed they used LO+10MHz and LO+20MHz. I can't figure out how that would make sense.
Secondly, since the cutoff at mixer output is only 8MHz, natually IF1(10MHz) and IF2(20.5MHz) will have different amplitude. So the question is, does the equation "IIP3=Pin+0.5(Pout-IM3)" still apply if IF1 and IF2 are different? If yes, should I use IF1 or IF2 in this case?
Lastly, does anyone know that in a WCDMA's datasheet when they specify IIP3, do they specify it at a particular RF input level?
Thank you so much.
  IP Logged
jefkat
Reply #3 - Aug 15th, 2005, 3:58am
sniff something fishy here .....why are u applying tones at the LO port ...shouldn't they be at RF port ...???
If you are interested in just the IP3 of mixer itself
You can do it with one tone as well .~(1dB compression+10dB).
And the equation is still valid ...Just consider the filter and mixer as two cascaded blocks... If the filter is attenuating it is just as good ....
    hope it helps.
    shafkat.
