ramakrishna
Hello Yawei, Thanks for the quick response. I am talking cyclic ADC.
I have gone through that paper you have referred.
I forgot to write one more specification of the ADC earlier, the input swing of the ADC is 0 to 3V and my VDD = 3.3V and VSS=0V. So ADC's input stage needs to scale(1/2) the inputs in order for the ota in the MDAC/Sample and Hold to operate.
I want to confirm another point with you, if I have single-ended analog input and I use differential MDAC structures having other input at common-mode. Will I still be having the advantage of offset cancellation because of the differential structure? or do I need to convert my single-ended input into differential initially to have that advantage.
Your comments will be very valuable to me.
Thanks, RK
