Aug 15th, 2024, 2:19pm
Cadence ic subcikt netlisting w/0 a schematic view (Read 4169 times)
Carl Chao
Guest
Aug 30th, 2005, 9:33pm
I'm using a Chartered 018um CMOS RF spice (hspice and spectre) library, in which all the MOS devices are defined as subcircuits.  I 'm trying to create a cadence library for this spice library so that I can do interactive simulations with the Analog Environment in Cadence.  But because of the large amount of parameters involved with these devices,  I don't want to waste time to draw a schematic (with ideal devices) for each device and specify  its parameters.  Instead, I just want to create symbols of the devices and hopefully make a subcircuit call to their spice library  after the Cadence netlisting procedure.  I used to use Mentor's da_ic, and I know da_ic can  perform netlist function if you provide only a symbol view and an (eldo)spice view.  That's a very convinent feature, especially  for RF design, because these days the rf spice model of the devices are so complicated that they must be modelled with lots of interconnected RCLs  etc., and they  can only be treated as a subcircuit instead of a primitive.
I tried to play around to see if I can sort the above problem through, but so far not so good.   Your help will be very appreciated!
Hopefully  Cadence also has the above mentioned feature, other wise I don't think Cadence will have too much attraction anymore, especially to the mixed signal design community now that Mentor also got its own version of RF simulator EldoRF ...
CC
  IP Logged
Re: Cadence ic subcikt netlisting w/0 a schematic
Reply #1 - Aug 31st, 2005, 6:00am
Does the subckt take the same pins and parameters as the basic MOS device?
(ie, you should have D G S B pins and L W parameters).  In which case, you should be able to put in the standard MOS device from a standard library (analogLib?) and just give the model name that points to the subckt.
It might be a little more difficult if you have a 5-terminal device (PMOS or NMOS in deep nwell) or if you need to vary the number of fingers (maybe you can write subckts for a couple fingers and call them rfnmos_16, rfnmos_32, etc. and have them call the master subckt).
-Geoffrey
Carl Chao
Guest
Reply #2 - Aug 31st, 2005, 8:45am
Hi Geoff,
Thanks very much for the reply.
Yes, these devices have the same pin and parameters as a common MOS device.  But if I use the standard MOS device from the standard library, the Cadence netlist would give me a device name started with M** instead of X** as for a subcircuit. (I'm not very familiar with Cadence, perhaps there's a way to change the prefix of the device name from like M** to X** automatically).
Best regards,
CC
  IP Logged
msl
Reply #3 - Aug 31st, 2005, 9:36am
Hi Geoff,
I have solved the problem after I checked one of the previous post by Andrew Beckett (thanks Andrew!!).  The link is:
http://www.designers-guide.org/Forum/?board=circuit;action=display;num=111894018...
Thanks!
CC
John O Donovan
San Jose, CA
Reply #4 - Aug 31st, 2005, 9:41am
If you are using Spectre as the simulator then the element name prefix 'X' or 'M' does not matter. As long as the pins and parameters that you are passing are accepted by the subckt, it will work as is, i.e.
 M1 d g s b nmos w=1u l=1u
nmos can be a model, subckt, Verilog-A module, primitive, etc.
 John
