Carl Chao
Guest
I'm using a Chartered 018um CMOS RF spice (hspice and spectre) library, in which all the MOS devices are defined as subcircuits. I 'm trying to create a cadence library for this spice library so that I can do interactive simulations with the Analog Environment in Cadence. But because of the large amount of parameters involved with these devices, I don't want to waste time to draw a schematic (with ideal devices) for each device and specify its parameters. Instead, I just want to create symbols of the devices and hopefully make a subcircuit call to their spice library after the Cadence netlisting procedure. I used to use Mentor's da_ic, and I know da_ic can perform netlist function if you provide only a symbol view and an (eldo)spice view. That's a very convinent feature, especially for RF design, because these days the rf spice model of the devices are so complicated that they must be modelled with lots of interconnected RCLs etc., and they can only be treated as a subcircuit instead of a primitive.
I tried to play around to see if I can sort the above problem through, but so far not so good. Your help will be very appreciated!
Hopefully Cadence also has the above mentioned feature, other wise I don't think Cadence will have too much attraction anymore, especially to the mixed signal design community now that Mentor also got its own version of RF simulator EldoRF ...
CC
