Aug 15th, 2024, 10:24pm
How to measure PSRR in spectre (Read 3354 times)
SIRIUS
cyberjaya, malaysia
Aug 30th, 2005, 10:13pm
Hi ,
Can anyone guide how to simulate for PSRR of voltage regulator using cadence spectre.Thanks in advance.
Re: How to measure PSRR in spectre
Reply #1 - Sep 1st, 2005, 7:16pm
SIRIUS,
 Do you mean line and load regulation of the Voltage Regulator
or PSRR of the op-amp used in the Voltage Regulator? Are you
interested in small-signal effects, for example, 60dB of rejection,
or are you interested in large signal effects, 3mV/V of supply
variation?
SIRIUS
cyberjaya, malaysia
Reply #2 - Sep 2nd, 2005, 11:24pm
I mean line and load regulation of the Voltage Regulator & interested in small-signal effects & large signal effects.
