Aug 16th, 2024, 12:26am
PFD simulation problem with EldoRF (Read 2389 times)
trashbox
Aug 31st, 2005, 2:26am
I used EldoRF to simulate the phase noise of PFD in PLL. However, the steady-state analysis can not be converged so that EldoRF can not continue the phase noise analysis. I have changed the related options(reltol & eps, sst_convergence_help etc.), there is no use.
Then I put some small capacitors(~2fF) on the nodes of PFD's circuit by hand. For example, on the nodes of INV's output and DRAIN of nmos in NAND. The steady-state analysis of PFD can be converged. Why?
If my circuit is very complicated(i.e.,I can not put small capacitors by hand in the netlist file) and I also can not find any commands which can add small capacitors on the node automatically. How to solve the steady-state analysis convergence problem during PFD simulation?
Thank you very much.
dguser
Re: PFD simulation problem with EldoRF
Reply #1 - Sep 13th, 2005, 1:39pm
I am curious what is the number of harmonics that you used in the simuation. Also did you turn on the pre-conditioner (option SST_PRECONDITION) and increase the solver iteration limit (option SST_MAX_LINITER)?
I would try TIME for pre-conditioner and increase  the number of harmonics. If still fails, I would contact the Mentor folk.
P.S: I am new to this forum. I tried to reply to this post earlier but am not sure if it went through. Anyway, sorry if you get duplicate responses.
