greety
I am simulating a closed-loop PLL with a sample-and-hold PFD/Loop Filter. To simulate the noise contribution of the loop filter I am using noiseless behavioral models for all blocks except for the loop filter, then running pnoise to check the phase noise at the vco output.
The pnoise results match my expectations at frequencies above the loop bandwidth, but for freqencies below the loop bandwith the noise continues to increase, which is not what I expect should occur. Any ideas as to why this is happening? I have tried modifying tolerances, tstab, nothing seems to affect it.
thanks, greety
