Aug 27th, 2024, 4:18pm
layout for R-ladder (Read 3702 times)
vivkr
layout for R-ladder
Sep 08th, 2005, 1:13am
I am designing an R-ladder DAC, and would like to get some feedback about the best way to minimize the INL. Because it is a series connection of resistors from
end to end, I see no solution for reducing the effect of linear gradients etc.
Does anyone have any suggestions on how to design or lay it out for good linearity?
Vivek
kwkam
Earth
Re: layout for R-ladder
Reply #1 - Sep 8th, 2005, 6:51am
I just you can use wider POLY resistor and place dump resistor around to improve resistor match. And also you can try to keep the current flow through the resistor chain constant. It can improve INL.
keble
Reply #2 - Sep 12th, 2005, 4:31am
Vivek, there's a useful book "Analogue-Digital ASICs" Ed R S Soin et al, published by Peregrinus (UK) 1991 ISBN 0 86341 259 9
This has a chapter on layout (chapter name is "Practical aspects of mixed analogue-digital design"). This discusses process variations, noise etc.
I've used the recommendations for many years with success, particularly for common centroid schemes, MOS switches and switched capacitors.
It has a really good example of DAC resistor ladder layout.
If you'd like a pdf just send me a message.
- Rob
