PNoise can compute noise figure in frequency translation circuits such as mixers, whereas sp (and noise) are limited to linear time-invariant circuits, such as simple amplifiers and filters.
If the noise figure from the PNoise analysis is hundreds of dB, then you have probably have configured the analysis improperly. Have you set refsideband correctly?
