Jess Chen
One other thing to consider when working with ports is that they have noise too. When you use (F-1) in the expression for input referred noise, you are neglecting the noise from the port. I suspect Spectre includes it when computing input referred noise. You may want to try replacing F-1 with just F to see if the numbers agree.
What numbers are you starting with? What input resistance are you using for the LNA model? What port resistance are you using? Exactly how are you computing integrated noise with Spectre and SpectreRF? Are you using the waveform display or are you using the noise summary printout?
Also, just for completeness I should ask about temperature. I assume all of your analyses are performed at the same temperature. If I could do it all over again, I would recalibrate the noise sources in my rfLib models to account for the difference in simulation temperature and port temperature. The ports are held at 16.85 degrees C. However, the default simulation temperature is 27 degrees C. So when you specify a particular noise figure, you will only see exactly that noise figure if you change the port temperature to 27 degrees C or the simulation temperature to 16.85 degress. For a noise specified figure of 2dB, you will measure 2.06dB unless you align the temperatures.
