Sep 1st, 2024, 6:23am
Error in Spectre simulation (Read 4381 times)
Ankush Goel
Guest
Sep 15th, 2005, 11:54am
Hi All,
I ran the following command for a circuit simulation...
spectre +cp -env artist5.0.0 +log ../psf/spectre.out -format psfbin -raw ../psf -I/home/ankush/tech_file/IBM_PDK/bicmos7wl/V1.3.1.0DM/Spectre/models/ input.scs
The following was the error message I got:
Error found by spectre during circuit read-in.
   ".bsource.va", line 13: "parameter real useii=0.0, pavc1=0.0, ppc=0.0,
       prhot=0.0, pavc3=0.0, temp=0.0, dtemp=0.0;<<--? "
   ".bsource.va", line 13: Error: real temp is redefined.
spectre terminated prematurely due to fatal error.
I am not able to locate the file bsource.va. Can anybody tell me where  to find  the path for the file.
Ankush
  IP Logged
Paul
Switzerland
Re: Error in Spectre simulation
Reply #1 - Sep 15th, 2005, 12:59pm
Ankush,
according to the error message, the filename is .bsource.va
The leading "." means it is a hidden file in the Unix/Linux file system, i.e. it does not appear using ls. The option -la to the ls command however shows hidden files.
I don't have access to Cadence right now, but it seems this should be related to the use of the bsource component for nonlinear resistors.  http://groups.google.ch/group/comp.cad.cadence/browse_thread/thread/ffbcdeb68907...
You can get more information by typing "spectre -h bsource", but I'm not sure that your problem is directly related to the bsource code. Probably Andrew will be able to help you out here...
Paul
Reply #2 - Sep 19th, 2005, 6:29am
I'll hazard a guess that ".bsource.va" is a Verilog-A description of a (customized?) bsource element provided in the IBM design kit.
find /home/ankush/tech_file/IBM_PDK -name ".bsource.va"
Reply #3 - Sep 19th, 2005, 9:09pm
Apologies for not responding sooner - I've been travelling a lot the last couple of weeks.
From looking at this I would have guessed that you were using an old version of the simulator - probably from the very early days of bsource support in spectre (possibly from when it was only an engineering version).
I see that you logged a service request, 33349726, with customer support - and they came to the same conclusion - the version you're using is from May 2003 - which was before bsource was fully released. That happend in IC5033, and as was found by the AE, this works in IC5033 versions and later.
