Sep 1st, 2024, 6:21am
Some question on Cadence (Read 2924 times)
reactgary
Sep 15th, 2005, 8:21pm
I am a new user of Cadence. I am going to make a chip using AMS 0.35um technology. I have some questions about the enviroment.
1) How can I display transistor instrict parameter (like gm, ro) when I in the schematic compresor?
2) When I am using the Analog enviroment to preform DC analysis. I use the calculator to print some DC voltage out. But it only contain 3 significant figure, how to increase the number of significant figure.
The quesitons may be silly...but I found the documents so long....
Thank You
GaRY
achim.graupner
Re: Some question on Cadence
Reply #1 - Sep 16th, 2005, 5:33am
Hi Gary,
ADE = Analog Design Environment
1: ADE~>Results~>Annotate~>DC Operating Points
or
ADE~>Results~>Print~>DC Operating Points, select devices afterwards
2. If you use the ADE-Ouputs (lower right) the space is limited, you migth use
Calculator~>Print (no autoupdate in this case)
ADE~>Results~>Annotate~>DC Node Voltages
good luck, next time ask your supervisor.
- achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
reactgary
Reply #2 - Sep 19th, 2005, 7:24pm
Thx achim.
