Ankush Goel
Guest
Hi All,
I ran the following command for a circuit simulation...
spectre +cp -env artist5.0.0 +log ../psf/spectre.out -format psfbin -raw ../psf -I/home/ankush/tech_file/IBM_PDK/bicmos7wl/V1.3.1.0DM/Spectre/models/ input.scs
The following was the error message I got:
Error found by spectre during circuit read-in. ".bsource.va", line 13: "parameter real useii=0.0, pavc1=0.0, ppc=0.0, prhot=0.0, pavc3=0.0, temp=0.0, dtemp=0.0;<<--? " ".bsource.va", line 13: Error: real temp is redefined. spectre terminated prematurely due to fatal error.
I am not able to locate the file bsource.va. Can anybody tell me where to find the path for the file.
Thanks, Ankush
