achim.graupner
Hi Gary,
ADE = Analog Design Environment 1: ADE~>Results~>Annotate~>DC Operating Points or ADE~>Results~>Print~>DC Operating Points, select devices afterwards
2. If you use the ADE-Ouputs (lower right) the space is limited, you migth use Calculator~>Print (no autoupdate in this case) ADE~>Results~>Annotate~>DC Node Voltages
good luck, next time ask your supervisor. - achim
