There are probably a few different ways to do this:
1) check the netlisting options available -- sometimes, even if the default is Spectre, you can ask for HSpice or CDSSpice or something that looks a lot more like standard spice, at least for simple circuits
2) write a translation script that converts Spectre to spice format: m1 (d g s b) modName w=1u l=1u just needs the parentheses removed, I think.
You'll need to do basic translation on the model libraries, too; model nch bsim3v3 would become .model nch nmos level=?? and you'd have to check your winspice documentation to see what level to use, and whether all the primitive models you need are available (eg, BSIM4 is not built into Berkeley Spice 3f5).
