Aug 15th, 2024, 6:08pm
help~ for AMS simulator (Read 4528 times)
sucki
Guest
Sep 22nd, 2005, 1:19am
hi,
when I run the cadence AMS,
"AMS Design Prep" (netlist compile) was passed,
and without any errors.
but when i start with "AMS run simulation",
it shows a error message as follows:
ncelab: *F,CUNOPN: Cannot open 5x configuration (adc.adc_top:config)
The HDBDI interface was unsuccessful in opening the specified configuration.
so, I can't start the simulation
Would anyone please help me~
thankfull~ Smiley
  IP Logged
Re: help~ for AMS simulator
Reply #1 - Sep 24th, 2005, 3:17am
Had you saved the config from the hierarchy editor? I can imagine this error would occur if you've created a new config, gone through the design prep, but not saved the config.
I've not done any checks or searches to see.
I also assume you're running the simulation from the hierarchy editor AMS plugin? Is that right?
bafiol
Reply #2 - Oct 15th, 2007, 12:26am
Hi, I have just got this problem. Do you know how to solve it.
thanks
