Hi Eric,
Ah, you're using the initial version with ADE (IC5141 Base release). I'd really recommend using IC5141 USR2 or later, as wavescan has had lots of improvements since then. I also found that I didn't have control over the annotations in the version you're using.
I think wavescan does use cdsplotinit to find the PostScript printers, in later versions (at least when run from ADE). Not sure about the bbox problem though - but it wouldn't surprise me if this had been fixed too.
