Jul 16th, 2024, 9:22am
Error message from divider model without HiddenSta (Read 2218 times)
tumeda
Sep 30th, 2005, 8:38am
Dear Ken Kundert
I reallly appreciate your answer for my previous questions. Now I tried to directly use the behavioral model codes of divider without hidden state. Unfortunately, there is an error message.
Error found by spectre during SpectreHDL compile.
       line 40:  Error: (Archaic Syntax) Does not comply with the Accellera
       Verilog-AMS 2.0 Standard and beyond. To comply with the current
       standard, delete the null statement. Null statements (also known as
       empty statements and coded as just `;') can be used only in case or
       event control statements.
After then, I deleted the semicolon ( ; ) in the line 40 and tried again. But there is still new error message:
       line 41:  Error: analog operator `ddt' embedded in conditionally
       executed statement or expression.
Now, I am confused about that, what's wrong?
My icfb version is  5.1.0 02/01/2005.
The following are only some lines of your codes.
analog begin
	vmax = max(abs(vdd),abs(vss));
	g = 5*ln(n);
	@(cross(V(pin,nin) - thresh, 0));
	// hold capacitor with capacitance tt
	I(vg,hold) <+ tt*ddt(V(vg,hold));
	// clamp hold capacitor during dc analysis
	if (analysis("static"))
	    I(vg,hold) <+ V(vg,hold);
Re: Error message from divider model without Hidde
Reply #1 - Oct 2nd, 2005, 12:38am
A whole bunch of extra checks were put into the verilog-a parser around the time of the version you're using - but some of these were reporting things that aren't really problems. These were fixed around March 2005 - so in IC5141 and MMSIM60 versions of spectre after that, the messages are no longer given.
I just tried the models from the hidden state paper in IC5141 USR2 and MMSIM60 ISR 10, and the warning is not given.
So use a later subversion, and the problem should go away.
