Thanks!
Also, how does one deal with the process variation (+/-15%) on Vbe which directly contributes to the tolerance of the bandgap voltage? The supply voltage is 1.2V.
And, how to minimize the contribution of input offset voltage (on the amplifier) to the bandgap voltage beside making the pnp's ratio larger (resistor ratio smaller) and careful layout?
Thanks!!
