Jul 20th, 2024, 11:31pm
Assura LVS passes incorrect (Read 3189 times)
asdf
Armenia
Oct 10th, 2005, 10:16pm
Whan running Assura second time for the same cell it sometimes shows correct results whan really there are errors.
I use Assura with the Virtuoso LE.
Why this is  the case and how the problem can be solved?
Thanks!
Bergerak
View Profile marimna   IP Logged
Re: Assura LVS passes incorrect
Reply #1 - Oct 12th, 2005, 1:41pm
No idea. You should contact Cadence customer support via whatever is your normal support channel, because this doesn't sound right...
