Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 18
th
, 2024, 5:24am
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› LC VCO doesn't oscillate in transient analysis
Previous topic
Next topic
LC VCO doesn't oscillate in transient analysis (Read 5982 times)
boshiouke
trying to learn
Oct 12
th
, 2005, 3:56pm
Can anyone comment on how to get the LC VCO to oscillate in transient analysis please? Initial conditions are set, and PSS/Pnoise works fine. But in transient analysis VCO simply doesn't oscillate. Thank you.
IP Logged
Re: LC VCO doesn't oscillate in transient analysis
Reply #1 -
Oct 13
th
, 2005, 6:32pm
Hi, boshiouke,
Have you checked the netlist again? Most errors are caused by circuit design, typo error in the netlist, etc.
Best regards,
Yawei
IP Logged
vborich
Reply #2 -
Oct 13
th
, 2005, 8:59pm
A small current pulse in parallel with the resonator should help. Setting integration method to trapezoidal and max time step to something on the scale of the expected oscillation period may help too.
IP Logged
zwtang
Shanghai, P.R.China
Reply #3 -
Dec 16
th
, 2005, 4:20pm
How did you set initial conditions? In my experiment, one oscillating point is set VDD, the other side VSS, LC VCO will start up in transient analysis. You can try it.
IP Logged
hrkhari
Reply #4 -
Jan 23
rd
, 2006, 2:31am
Hi Guys:
I just don't know how true is this, but I find the transient response is better if a damped vsin source is applied at the Vdd, and for PSS analysis a pulse source at the Vdd and a parallel pulse current source is used across the LC tank, I would appreciate if anyone could comment further on this.
Rgds
IP Logged
kokabanga
Reply #5 -
Jun 16
th
, 2006, 7:51pm
The problem could be the following!
Let us say your freuency of oscillation Fosc = 5GHz.
This implies the time period Tosc = 0.2 n secs.
Now, if you check the converegence options in the transient anaylsis form the time step for simulation will be 1 n sec.
This means SpectreRF will solve the circuit every 1 n sec, hence it misses your 0.2 n sec sine wave completely!
1) Set the convergence option in the transient analysis form to "conservative".
2) Set the "
MAXIMUM TIME STEP
" to "1/100" th of Tosc so that you get good convergence or interpolation...i.e set it to 2p sec!
Since you are setting the maximum time step to 2 p sec, if you try to "greedily" analyse the waveform for say 200 cycles of the sine wave or 200 x Tosc = 40 n secs then it will mean you need to wait for 40 n secs/ 2 p sec calculations to complete..or 20000 steps this might take a longgg time!
So try simulating for 10 or 20 cycles i.e. 4 n secs first!
forget the extra impulse to be added and all that!
such current impulse "concepts" are introduced by useless academicians!
naren
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
