Paul
you will have to provide more information to get a serious answer. It depends on the type of node you want to test (especially its impedance level) and the type of measurement equipment you want to connect (active probe, 50 Ohm load, etc).
If you need to add a buffer, you will not be able to avoid layout modifications, except if you can put your buffer off-chip.
Paul
