bsimtim
Hi, I have come across a problem in SpectreS of Cadence version ic5033. I have looked through this board and through the KPNS, and cannot find it there. I am trying to figure out if this is a bug in Cadence or a bug in our setup. The problem is this:
After running a PSS or SPSS simulation, I would like to access the results form to select, for instance, IP3 plots. However, from ADE, when I do Results->DirectPlot->PSS, the form never appears. It opens a new waveform window, and asks to select a net on the schematic window, but the plotting form never opens.
Has anyone seen this, or maybe know a solution?
Thanks, Tim
