Jul 18th, 2024, 4:14am
PSS Analysis (Read 7216 times)
Rahul_Prakash
Life is Analog
Richardson, TX
PSS Analysis
Oct 20th, 2005, 3:18pm
I am a new member of this forum. I am working on low phase noise, high speed divide by two frequency dividers. I am using Cadence spectre for the PSS and Pnoise analysis.
I wanted to know what exactly PSS analysis do and what parameters it pass on to Pnoise setup as when ever i run PSS it finds a convergence point after some iteration and then starts Pnoise analysis.
Is there any website where i can learn how cadence spectre does PSS analysis.
Rahul
We are what we repeatedly do,
excellence is therefore not an act but a habit.
-- Aristotle
View Profile WWW sacten2001   IP Logged
Re: PSS Analysis
Reply #1 - Oct 21st, 2005, 3:44am
Well, did you try reading the documentation? The SpectreRF User Guide and SpectreRF Theory manuals in cdsdoc are a good starting point.
Also, the papers on this site, in the Analysis section, are also helpful. One good starting point is:
http://www.designers-guide.org/Analysis/rf-sim.pdf
Rahul_Prakash
Life is Analog
Richardson, TX
Re: PSS Analysis
Reply #2 - Oct 21st, 2005, 8:14pm
Thanks for the reply
Yes i did tried various documents that i could find using google about PSS analysis, though i did not read spectra guide. All of them refered to just 1 theory that in PSS analysis the circuit is activated by a periodic signal and PSS analysis calculates some parameters when the the output is periodic itself. These parameters are used by Pniose setup to calculate phase noise spectra. Thats all i could find.
Will read user guide.
Rahul
-- Aristotle
neoflash
Mixed-Signal
Designer
Re: PSS Analysis
Reply #3 - Nov 5th, 2005, 6:50am
I also need to read some related document.
Can anyone upload here?
