May 18th, 2024, 12:46pm
how to pass a string in Verilog-A (Read 25200 times)
RobertZ
the art of analog
San Diego, CA
Nov 01st, 2005, 10:56am
Hi, all,
I want to pass a string as a parameter, but don't know how to define and use string in verilog a (not verilog ams).
I tried like this:
  parameter string string_name = "abc"
but there is a syntax error, which complains "string"
Thanks a lot,
-driveforce
Robert
RobertZ
the art of analog
San Diego, CA
Re: how to pass a string in Verilog-A
Reply #1 - Nov 1st, 2005, 12:27pm
I found one article inside this forum, which is quoted here.
Verilog-AMS LRM 2.2 adds support for string parameters, which must be declared as such:
 parameter string outfile = "foo.dat";
Alas, Accellera has not yet voted on these extensions, so vendors have not implemented them.
The current support for "strings" in Verilog-AMS is the variable type "reg" (see section 2.6 of the current LRM); also, there is a format specifier "%m" that is supposed to return the hierarchical name of the instance.  There's an off chance that you can use these, eg,
 reg [8*40:1] outfile;
 integer fh;
 outfile = "%m";
 fh = $fopen(outfile);
or
 fh = $fopen("%m");
though I somewhat doubt this will work (%m probably only works in $strobe).
You might be able to do something like
 parameter integer blocknum=0;
 integer fh;
 outfile = "output_";
 outfile[8] = blocknum+48; // 48==ascii offset of "0"
-Geoffrey
But it didn't work in my simulator.
after I use keyword "reg", an error notice appeared:
Warning from spectre during SpectreHDL compile.
   "/projects/driveforce/lib/private/mylib/temp/veriloga/veriloga.va",
       line 10: Warning: `reg' is a future reserved keyword, parsing as
       identifier.
Error found by spectre during SpectreHDL compile.
       line 10: "reg [8*30:1] File_name;<<--? "
       line 10: Error: syntax error
Robert
Jess Chen
California Bay Area
Reply #2 - Nov 1st, 2005, 1:15pm
To my knowledge, you cannot pass a string as a parameter into a VerilogA module, at least not in Cadence's VerilogA. Although such a capability would be really, REALLY, useful, especially now that we have table models available.
RobertZ
the art of analog
San Diego, CA
Reply #3 - Nov 1st, 2005, 3:34pm
Hi, Jess,
Thanks for your reply.
I made it work by Spectre HDL.
-driveforce
btw, I noticed you wrote lots of verilog-a example in cadence.
Robert
Jess Chen
California Bay Area
Reply #4 - Nov 1st, 2005, 4:24pm
I worked at Cadence from 1995 to 2000. While I was there I worked on the rfLib, pllLib, j/k models, and some of the AWB library. I wrote the J-model in rfLib using SpectreHDL for exactly the reason you found.
Reply #5 - Nov 1st, 2005, 9:55pm
Jess,
Actually this can now be done with Verilog-A. I used:
parameter filename = "test.out";
within the code I then did:
$display("%s\n",filename);
and I can quite happily pass filename="something" on the instance line in the spectre netlist.
This certainly works in MMSIM60 (not tested it in earlier versions). In MMSIM60 USR2, there is going to be support for following the 2.2 LRM way of doing:
parameter string filename = "test.out";
RobertZ
the art of analog
San Diego, CA
Reply #6 - Nov 2nd, 2005, 2:24am
Hi, Andrew,
yes, I tried what you said, file names can be passed.
but I have another problem.
I tried to instance a pwlf voltage source in verilog-A, as following:
vsource #(.type("pwl"), .file("data.txt"), .delay(delay_time), .offset(dc_offset)) v1(plus, minus);
an error said "delay" is an reserved name for simulator library function.
by the way, where should I instance vsource?
-driveforce
Robert
Jess Chen
California Bay Area
Reply #7 - Nov 2nd, 2005, 11:26am
Thanks for the tip Andrew!
-Jess
Reply #8 - Nov 4th, 2005, 4:55am
Driveforce,
I answered your delay question in the other thread where you posted this - http://www.designers-guide.org/Forum/?board=verilogams;action=display;num=113106...
