Aug 19th, 2024, 10:20am
SPICE MODEL (Read 2843 times)
hchanda
SPICE MODEL
Nov 02nd, 2005, 6:07pm
Hello Everyone,
How do you find NRD/NRS= number of squares for drain/source resisitance for a MOSFET?
Please let me know.
~H
hc
keble
Re: SPICE MODEL
Reply #1 - Nov 7th, 2005, 1:40pm
Just use this: NRD (or NRS) = Ldiff/W where Ldiff is the length of the drain/source diffusion (ie, the dimension from the poly gate edge to the edge of the diffusion) and W is the width of the transistor.
This gives an approximate answer - you could get more accurate if you need to by taking into account the sideways diffusion.
Rob
