Aug 29th, 2024, 1:22pm
output load consideration (Read 6043 times)
vijay
Nov 03rd, 2005, 8:49pm
Hi friends,
I have a symmetric load differential VCO.How do I take care of the output load considerations in my design? Or how do i design my VCO with fanout considerations.
Thanks in advance.
Re: output load consideration
Reply #1 - Nov 7th, 2005, 8:09pm
It's just a capacitive load, which affects the oscillating frequency of the VCO. Smiley
Yawei
vijay
Reply #2 - Nov 9th, 2005, 2:06am
But what I meant to say that, if I use this VCO in a PLL circuit, which in turn is acting as a clock.Then there has to be certain consideration for the load which the PLL has to drive.This is like fanout consideration in the digital design side.Since it will be the VCO which has to drive the load so how do I design a VCO taking this fanout or load consideration.
Reply #3 - Nov 21st, 2005, 9:12pm
Vijay,
Normally the PLL block must have digital interface. You'd better put some inverters at the output of the VCO. Then the unpredicted digital design don't load the VCO directly.
Best regards,
Yawei
uncle_ezra
Reply #4 - Nov 22nd, 2005, 12:57am
Well normally u have a buffer in between so you can design them sort of independently.
vijay
Reply #5 - Nov 27th, 2005, 8:18pm
This is the output buffer design,
I got it.
Thanks.
V
singh
Reply #6 - May 30th, 2011, 5:22am
can ushare the buffer design?? i designed my VCO keeping 1pF at the load but if i increase load capacitance,the oscilation frequency increases.Please let me know the buffer design
Reply #7 - May 30th, 2011, 6:09pm
singh wrote on May 30th, 2011, 5:22am:
um, probably decreases....
