Jul 20th, 2024, 12:30pm
AVANWAVES Help I canīt see Delta X. (Read 1955 times)
negil
Nov 03rd, 2005, 9:19pm
Does anybody knows what should I do to see Delta X in the window panel in Avanwaves.
I am measuring propagation delay but I canīt see Delta X when I click the output waveform with point to point measurement even though I have marked Delta X in Measurement lanel options.
Is there any other way to measure propagation delay in avanwaves than using Delta X?
spiceoracle
USA
Re: AVANWAVES Help I canīt see Delta X.
Reply #1 - Jan 5th, 2006, 2:58pm
Are you trying to do a point to point measurement between two signals?  If so, this is not possible in AvanWaves.  The point to point measurement will only give you the delta between two points on the same signal.
