Jul 20th, 2024, 12:29pm
.opt not working (Read 2453 times)
modern_analog
.opt not working
Dec 29th, 2005, 6:12pm
When I run cadence analog artist, I can get .op working from calculator
However, I can never get .opt (which I believe is op point during transient)?
Do you have to do anything special
Also does anyone have any good link to analog waveform viewer (AWD) manual - I always get stuck at some of the more advanced things and don't want to clutter up this board
Re: .opt not working
Reply #1 - Jan 3rd, 2006, 10:13pm
I don't think anything special is needed to use the OPT button in the calculator. It prompts you to select an instance, and then you choose the operating point parameter from the pulldown list. This uses the finalTimeOP-info data from the psf directory. This generates the expression in the calculator, which you can then use as normal.
As for the manual, you can find this in your installation, either using cdsdoc or by looking at <instdir>/doc/anawavefm/anawavefm.pdf . If using a recent version, there's also the wavescan/wavescan.pdf document.
