Jul 21st, 2024, 2:23pm
save operation region with spectre? (Read 2949 times)
Narya
I love spectre,
Cadence IC 5.0!
Nov 04th, 2005, 5:20pm
Hi guys, with spectre I tried to save the operation region of a MOS transistor using following statement:
save M1:region
However, spectre complained that "region" is an invalid parameter and ignored the statement. The "region" parameter is indeed listed as one of the operating-point parameters for BSIM3v3 model in spectre documentation. I tried several other op-point parameters such as gm and vth, and spectre worked well.
So how can I save the operation region ONLY? Any help is appreciated, thanks a lot!
rf-design
Reiner Franke
Re: save operation region with spectre?
Reply #1 - Nov 6th, 2005, 12:49pm
I am not shure but if you type
spectre -help bsim3v3
you will get a list of model/instance/op parameter. You have to possible use another syntax.
Reply #2 - Nov 15th, 2005, 11:33am
I just tried this, and you're right. It doesn't work. I found PCR 697454 which suggested it was fixed in MMSIM60 - but it doesn't seem to be when I tried it.
I'll check why not...
