kindly take a look on the
http://www.designers-guide.org/Analysis/sc-filters.pdfthere is a tstab option in pss analysis that u need to fill in the time ur circuit need to stabilize. if u leave out the tstab, most probably the pss will not converge. to confirm that the pss is valid, check out the pss result with result browser. it works for me so dun worry about the sc-cmfb
the pnoise spectrum is the the paper by kendurt, it looks like 1/f + thermal to me... y should it looks periodic?
according to the pnoise paper, number of sideband determines the accuracy of the result, kindly take a look at the paper for more detail guideline.
about the total noise power, it should depends on ur antialiasing filter bandwidth in front of the sampling circuit. note that u should intergrate starting from 0Hz, otherwise u missed out a lot of 1/f noise.
hope that help.
chase
