Zorro
If someone is interested, here is the ram in verilogA using Mokokoya's idea of converting a matrix in a 1D vector.
`define DATA_BITS 8 `define ADDR_BITS 2
module ram_va(READ_NWRITE, ADDR, CE, DATA, REF, Qb); input READ_NWRITE, CE; input [`ADDR_BITS-1:0] ADDR; input [`DATA_BITS-1:0] DATA; output [`DATA_BITS-1:0] Qb; inout REF; electrical READ_NWRITE, CE; electrical [`ADDR_BITS-1:0] ADDR; electrical [`DATA_BITS-1:0] DATA; electrical [`DATA_BITS-1:0] Qb; electrical REF;
parameter integer MEM = (pow(2,`ADDR_BITS)*`DATA_BITS); parameter real vth = 2.5; parameter real dig_v = 5.0;
integer addr_aux; integer ce_aux, r_nw_aux; integer data_aux_in[`DATA_BITS-1:0]; //it's the value read from the input port DATA integer data_aux_out[`DATA_BITS-1:0]; //it's the value assigned to the output port Qb integer k, bit, i, m; integer memory[MEM-1:0]; analog begin
ce_aux = 0; r_nw_aux = 0; addr_aux = 0; bit = 0; generate i(`DATA_BITS-1, 0) data_aux_in[i] = ((V(DATA[i]) > vth) ? 1: 0); // data_aux_in = DATA generate i(`ADDR_BITS-1, 0) addr_aux = addr_aux +((V(ADDR[i]) > vth) ? 1 << i:0); // addr_aux = ADDR r_nw_aux = (V(READ_NWRITE) > vth) ? 1:0; // r_nw_aux = READ_NWRITE ce_aux = (V(CE) > vth) ? 1:0; // ce_aux = CE for (k=addr_aux*`DATA_BITS;k<=(((addr_aux+1)*`DATA_BITS)-1);k=k+1) begin if ((r_nw_aux==1)&&(ce_aux==1)) begin data_aux_out[bit] = memory[k]; bit = bit+1; end else if ((r_nw_aux==0)&&(ce_aux==1)) begin memory[k]= data_aux_in[bit]; data_aux_out[bit] = 0.1n; bit = bit+1; end else begin data_aux_out[bit] = 0.1n; bit = bit+1; end end generate i(`DATA_BITS-1, 0) V(Qb[i], REF) <+ data_aux_out[i] * dig_v; end endmodule
