May 1st, 2024, 9:02am
Verilog-A RAM Model (Read 8358 times)
Zorro
Verilog-A RAM Model
Nov 21st, 2005, 3:27am
Hello everybody,
I've written a simple verilog-AMS model for a RAM. Now I have to rewrite that model, but in verilog-A.
I'am not very experienced in verilog-A and I'd like to know if it's possible to declare a matrix, as in Verilog-AMS eg. reg [7:0] memory [255:0].
The verilog-AMS code is:
`timescale 1s/1ns
`define width 8
`define length 256
module RAM_INOUT ( READ_NWRITE, ADDR, CE, DATA);
     input READ_NWRITE, CE;
     input      [`length-1:0] ADDR;
     inout      [`width-1:0] DATA;
     reg [`width-1:0] memory [`length-1:0]; // RAM 256x8: 256 8-bit words
     assign DATA = (READ_NWRITE && CE) ? memory[ADDR] : 'hz;
     always @(ADDR or READ_NWRITE or DATA or CE)
           if (!READ_NWRITE && CE) memory[ADDR] = DATA;
Or if you have any suggestion. Thank you.
MokoKoya
Re: Verilog-A RAM Model
Reply #1 - Nov 23rd, 2005, 7:29am
Hello Zorro,
I have had a little experience in Verilog-A, and in RAM models. When it comes to creating the memory matrix, I find it easy to do it in the following way.
If I have 256 lines of memory @ 8 bits each (for example), I multiply the two and declare memory as:
integer  memory[256*8 -1:0];
In other words, make the matrix 1D instead of 2D. Now address 0 is assigned the first 8 bits of memory, address 2 the next 8 bits of memory and so on.
Hope this helps,
Andrew  ;D
Zorro
Reply #2 - Nov 29th, 2005, 1:07am
Hello Mokokoya,
Thanks for your idea of converting a 2D matrix into a 1D vector.  This worked very well although was a little tricky when accesing and transfering addresses and data.
Thank you very much.
Zorro
Reply #3 - Dec 1st, 2005, 4:50am
If someone is interested, here is the ram in verilogA using Mokokoya's idea of converting a matrix in a 1D vector.
`define DATA_BITS  8
`define ADDR_BITS  2
module ram_va(READ_NWRITE, ADDR, CE, DATA, REF, Qb);
     input      [`ADDR_BITS-1:0] ADDR;
     input      [`DATA_BITS-1:0] DATA;
     output      [`DATA_BITS-1:0] Qb;
     inout REF;
     electrical READ_NWRITE, CE;
     electrical [`ADDR_BITS-1:0] ADDR;
     electrical [`DATA_BITS-1:0] DATA;
     electrical [`DATA_BITS-1:0] Qb;
     electrical REF;
     parameter integer MEM = (pow(2,`ADDR_BITS)*`DATA_BITS);
     parameter real vth = 2.5;
     parameter real dig_v = 5.0;
     integer addr_aux;
     integer ce_aux, r_nw_aux;
     integer data_aux_in[`DATA_BITS-1:0]; //it's the value read from the input port DATA
     integer data_aux_out[`DATA_BITS-1:0]; //it's the value assigned to the output port Qb
     integer k, bit, i, m;
     integer memory[MEM-1:0];
     analog begin
           ce_aux = 0;
           r_nw_aux = 0;
           addr_aux = 0;
           bit = 0;
           generate i(`DATA_BITS-1, 0) data_aux_in[i] = ((V(DATA[i]) > vth)      ? 1: 0); // data_aux_in = DATA
           generate i(`ADDR_BITS-1, 0) addr_aux = addr_aux +((V(ADDR[i]) > vth)      ? 1 << i:0); // addr_aux = ADDR
           r_nw_aux = (V(READ_NWRITE) > vth) ? 1:0; // r_nw_aux = READ_NWRITE
           ce_aux = (V(CE) > vth)      ? 1:0; // ce_aux = CE
           for (k=addr_aux*`DATA_BITS;k<=(((addr_aux+1)*`DATA_BITS)-1);k=k+1) begin
                 if ((r_nw_aux==1)&&(ce_aux==1)) begin
                       data_aux_out[bit] = memory[k];
                       bit = bit+1;
                 end else if ((r_nw_aux==0)&&(ce_aux==1)) begin
                       memory[k]= data_aux_in[bit];
                       data_aux_out[bit] = 0.1n;
                       bit = bit+1;
                 end else begin
                       bit = bit+1;
           generate i(`DATA_BITS-1, 0) V(Qb[i], REF) <+ data_aux_out[i] *  dig_v;
