Aug 14th, 2024, 7:18pm
What does Spectre pnoise output: Sv or Sphi? (Read 5993 times)
Kiran B R
Guest
Nov 21st, 2005, 5:53am
Ken,
In "An introduction to cyclostationary noise", you say "PNoise computes Sv but does not predict the corner frequency".
If that's true, why do I sometimes see PNoise in dBc go above 0dB? What does it mean when PNoise is > 0dB 100Hz from the carrier?
Cheers
Kiran
  IP Logged
Re: What does Spectre pnoise output: Sv or Sphi?
Reply #1 - Nov 21st, 2005, 3:35pm
Kiran B R
Guest
Reply #2 - Nov 21st, 2005, 4:30pm
Ken,
That section didn't answer my question. Can you please explain?
Cheers
Kiran
  IP Logged
Reply #3 - Nov 21st, 2005, 9:27pm
Okay, try Section 3.2 in http://www.designers-guide.org/Analysis/rf-sim.pdf, especially pay attention to pages 12 & 13, especially the text found between (18) and (19).
Kiran B R
Guest
Reply #4 - Nov 22nd, 2005, 12:04am
Thanks. That was an eye opener.
Sorry to prolong this thread, but should I *always* estimate the corner frequency after running PNoise?
  IP Logged
Reply #5 - Nov 22nd, 2005, 12:07pm
Normally, the corner frequency is so low that it is not a concern. This is because the noise is generally very small. However, if you have a very high noise oscillator or an application where you are concerned about very close in phase noise, then you should estimate the corner frequency. In addition, if you are using PXF analysis to estimate the phase modulation that results from noisy supplies or substrates, then the noise source could be large and you should always use the power in the response to determine whether you are above or below the corner.
