Jul 16th, 2024, 10:57am
veriloga -> loop of rigid branches (shorts) (Read 9207 times)
marben
Nov 25th, 2005, 6:46am
I would realise a polarisation stage in veriloga language.
I need to instantiate 80 similar polarisations stages (PolaStage<79:0>).
Each stage has the same input current (in) but not the same output voltage (out<79:0>).
So if I have a current source of 80ľA, each stage see only 1ľA.
To simplify my problem, I wrote :
> branch (in,gnd) toto
> analog begin
>     outval = K * I(toto);
>     V(out) <+ outval;
> end
the parser didn't see error but when I start spectre, I have a fatal error  >:( :
The following branches form a loop of rigid branches (shorts) when added to the circuit :
PolaStage_0:in_flow (from in to 0)
PolaStage_1:in_flow (from in to 0)
PolaStage_2:in_flow (from in to 0)
PolaStage_3:in_flow (from in to 0)
Is it really impossible to write a veriloga close to the schematic in this case ??
Thanks for your help
Ben
Re: veriloga -> loop of rigid branches (shorts)
Reply #1 - Nov 27th, 2005, 5:19am
The trouble is that each of your 80 current probes is essentially a zero-volt source between in and gnd - and so each of these are in parallel, and thus causes the loop of rigid branches.
You could put some impedance in series with the current probe, but I'm not sure that's really what you want - because are you really measuring the current properly then? Perhaps you need to separate the current measurement using (say) a current-controlled voltage source (e.g. a ccvs) and then connect the voltage output of this to all the 80 stages?
There's almost certainly other ways of solving this, but this was the first that came to mind (especially without knowing the details of what you're really trying to achieve).
Reply #2 - Nov 30th, 2005, 12:39pm
I'd lean towards using a bus in the module
module polar(in, out);
inout in;
inout out[79:0];
electrical in;
electrical out[79:0];
parameter real K = 1;
real ibr;
genvar idx;
analog begin
 ibr = I(in,gnd);
 for (idx=0; idx<80; idx = idx + 1) begin
  V(out[idx]) <+ K * ibr;
If your gain K differs, then you'd need
 parameter real K[79:0] = { };
and you'd need to put 80 values in the braces {}.
marben
Reply #3 - Dec 1st, 2005, 1:43am
thanks for all.
Yes, it was a zero volt problem..
I put some input impedance and it work properly. The input current is create by another veriloga block and it is independant of the impedance.
ben
Reply #4 - Dec 1st, 2005, 3:55am
I'm still unsure whether the input current is supposed to be split among all 80 stages, or whether each one is supposed to depend on the full value (which is what my suggestion does).
I mention this for later readers of the forum, as you've solved your problem.
