vijay
Hi, Require a help in simulating a single delay cell. Case 1: For Vctrl=2.25, I found out the required bias voltage for the tail transistor to maintain Vswing=Vdd to Vctrl at the output.It comes out to be 1.871V. The dealy cell shows the same Vswing even when a PWL source is used at its two inputs. Case 2:- When I attach a Cload = 71fF for a 0.6um process the swings in the two arms vary.The observed results are:- When In+ = 5--2.25V; Vop- = 2.25--4.3V. Simultaneously In- = 2.25--5V;Vop+ = 5--3V. I cannot understand why this variation in the swing happens??? When the Cload is not connected the oputput swing behaves accurately:-Vop+ = 5--2.25V and Vop- = 5--2.25V. What could be the possibel reason for this behaviour.
Further more should I use a Vpulse to calculate the time delay of this cell for this Vctrl. Thanks in advance, V
