Jul 17th, 2024, 3:28pm
Jitter while testing ADC (Read 512 times)
Sid
Nov 28th, 2005, 7:41pm
Does only "clock source" jitter affect my SNR while testing my ADC, or does the jitter in my "input signal" also matter?
I am loaning a state-of-the-art low-jitter clock source for testing my 14 bit ADC, but I will still be using a "value price" function generator for my input signal. Do I have to worry about the jitter in my input signal? I will be using a band-pass filter to improve the harmonic distortion of the input signal before it is applied to my ADC.
Sid
Re: Jitter while testing ADC
Reply #1 - Nov 28th, 2005, 10:37pm
Hi, Sid,
I think the jitter in the input signal affects the testing because that jitter deteriorates the SNR of the input signal. However, the SNR of the input signal affects the testing directly. So just find the SFDR, SNR and THD parameters in the manual of your signal generator.
To test such a high resolution ADC it is a good idea to filter the input signal if you have not good enough signal generator. Smiley
Look into this problem from another perspective, the clock source and input signal are locked to the same reference timing clock. So we assume the clock source is phase locked to an sine wave w/o jitter (the input signal). So we only need know the jitter of the clock source.
Best regards,
Yawei
