Aug 15th, 2024, 6:26am
OTA macro-model (Read 4574 times)
Visjnoe
OTA macro-model
Nov 29th, 2005, 4:25am
maybe this topic is a bit too trivial for some of you, nevertheless...
Let's assume I want to model (Verilog-AMS, so no SPICE macro-modeling) a CMOS OTA with the dominant pole at its output (e.g. symmetrical CMOS OTA).
In most code snippets I have seen, most people tend to put a Laplace transfer function inside the OTA model and include the output impedance using a real parameter, finally using a statement as this:
I(outp,vss) <+ V(outp,vss)/rout
My question is as follows: if the capacitive load (SPICE primitive) of the AMS-model of the OTA  changes, will the output pole of the overall model change?
Or: thus the real parameter 'rout' interact with a SPICE primitive to form a pole 1/(2*pi*rout*C), which can, e.g. be seen in an AC analysis?
Kind Regards
Peter
Re: OTA macro-model
Reply #1 - Nov 29th, 2005, 9:13pm
Peter,
  Yes the pole will change, as it should. Remember, Op-Amps
are supposed to low output impedenace and insensitive to
output loading. While an OTA is high output impedance and
sensitive to output loading.
